Which circumference value do I have to use?
Re: Which circumference value do I have to use?
I recently got the Suito and after the calibration I had a few rides to test it out. I noticed that the power reasons are low compared to my usual so I did a ride with the Favero Assioma and as suspected the power is too low. I did recalibrate but it’s the same.
[urlhttps://]vidmateapp.win[/url] | moviezwap | spice money login
Contact our customer care:
Specify the problem and the trainer serial number.
Wheel diameter = (rim diameter) + (tire diameter * 2). Wheel circumference = Wheel diameter * PI. You should try this formula
Users browsing this forum: Google [Bot] and 2 guests
