How To Calibrate The Direto
I'm having trouble calibrating my Direto. I have the Elite Training App. I set up Parameters fine (I went with the default circumference since I don't have power and cadence on my bike, I'm just relying on the Direto itself for that). There is no calibration, however. I figure it might be part of "Pedaling Analysis" so I enter my code to get a free year of all the services on the App and click on Pedaling Analysis. It tries to charge me money and I'm not paying money for a possible calibration. What am I missing?
Re: How To Calibrate The Direto
To do the calibration, there must be no external power sensor.
Do again the configuration and be sure to not select "yes" when you're asked if you have external power sensors.
Then you'll find the calibration on the advanced settings menu.
Pedal analysis is a different feature:
http://drivo.cc/system/cms/document/dat ... sis_02.pdf
Is it possible to calibrate the direto with an other app besides the mytrainingapp? Like, e.g. With zwift?
@b.vernhout@live.nl did you manage to do the calibration with the My Training app?
I am trying but doesn't seem to work either.
it gives no instructions except for ' start peddling' and then it does nothing else...
@helen.schott1
It looks like either the trainer is not "seeing" the strokes which could be a sensor issue, or a connection problem. Is there any led flashing? Or it could be a setting problem. In another thread you mentioned you can't change the circumference, so maybe your trainer is not properly set/connected to the app.
