10 Speed cassette help for Drivo
Posted: Thu Nov 30, 2017 5:14 pm
by LouisonBobet
Hi Guys,
I am hoping someone could please help me. I have just purchased the Elite Drivo. I have a 10 speed cassette which I would like to install on my new Drivo. Do I use the 2 spacers that come with the trainer as well as the metal spacer that is provided with the cassette? Or do I just use the 2 spacers provided with the trainer from Elite.
Re: 10 Speed cassette help for Drivo
Posted: Fri Dec 15, 2017 12:54 pm
by Elite Admin S
One spacer of the ones we put in the box should be enough with a 10 speed cassette.
But depends on the specific situation. Try with one and check if all is well fixed, otherwise add the second one.
Posted: Fri Dec 15, 2017 3:44 pm
by sebrios
I had to use both spacers that came with the drivo + 2 spacers from the cassette itself.
I installed a 10speed sunrace (Mtb) if that works for something
Posted: Fri Dec 15, 2017 6:46 pm
by chrisper
I used 2 Spacer with my Shimano XT cassette CS-M771-10
Posted: Mon Jan 01, 2018 6:12 pm
by LouisonBobet
Thanks guys. Mine is a 10 speed Ultegra cassette. Is this different?
