When I use my Elite Turbo Muin trainer, it is as if the trainer's flywheel "slips" a bit out of the way when I pedal hard (about 200W and more uphill in Zwift). I've tried tightening the V-belt, but it didn't get much better. Any suggestions as to what could be causing the error?
With best regards
Jan
Flywheel "slips" at bit out of the way when I padal hard
Re: Flywheel "slips" at bit out of the way when I padal hard
Hi Jan
You've done the correct thing tightening the belt, but if this was not enough there may be some other problem.
Please contact the support, the guys there will help you to find the cause of the issue:
Users browsing this forum: Bing [Bot] and 54 guests
