I have a drivo 2 and although this trainer is picked up automatically the Cadence does not work correctly so I use the meter off the 4iii.
I also notice that in the System X settings you can select a trainer from a variety of manufacturers including Elite; however there is no Drivo listed.
Can anyone, preferably Elite, advise which should be selected, or should they all be ignored.
Cheers
wahoo system x
