Hi all / Elite Help,
I've had an Elite Turbo Muin trainer for a few years now.
It comes with a Misuro B+ Sensor
Could someone advise what to do with this problem please?
Turbo Muin Trainer S/N 15433
Misuro B S/N 333017 c Firm:17
First thing is that there seems to be no clear instructions as to how the Misuro should be setup. Is it 12 blinks, is it 2 blinks, or is it 15 blinks?
Second thing is why does there seem to be no explanation of why, when using the trainer with Zwift, there is a warning that the battery is low... even with a new battery on it. The signal drops out and is essentially useless as a smart trainer.
Having read up on this problem, this is a very common issue and Elite are clearly aware of it but there appears to be no solution offered other than "buy a new one".
Can anyone offer a solution/some advice that will get this great trainer up and running again. I'm very reluctant to throw good money after bad buy buying a new Misuro unit if this is indeed something Elite know about but have no solution for other than buying a new trainer.
Thanks in advance!
Turbo Muin and Misuro B+ sensor
Re: Turbo Muin and Misuro B+ sensor
In the Misuro B+ user manual the number of blinks to set is indicated quite clearly:
https://drive.google.com/file/d/0B_4_od ... D1CGu4XmdQ
As you can see, you have to set 2 blinks.
About the low battery signal... this is due to a bad translation of some data packet.
Some device and application misunderstood the data and send a low battery signal when the battery level is ok.
Ignore the message and change the battery only when data are not sent anymore (or you have frequent disconnections)
Users browsing this forum: No registered users and 54 guests
