Rizer and drivo 2 compatability
So when my bike is mounted to my drivo 2 it can swivel up and down just fine. Why isn't drivo listed as a compatible device. And pivoting aside does the trainer have the neccessary technology to run the rizer motion. Any input would be great thanks all. MASSIMO
Re: Rizer and drivo 2 compatability
Hi Massimo
Rizer is compatible only with Direto XR/XR-T, Suito/Suito and Tuo
These models allow the bicycle to rotate on the home trainer, therefore ensure the proper movements while using the Rizer.
Those Elite home trainers not listed above cannot be used with Rizer as they do not allow the proper bicycle rotation on the rear hub.
Your bike shouldn't rotate up and down as you say. Not smoothly, at least.
Using Rizer with any Elite home trainer not listed above might cause severe damages to your bicycle's frame over time
