FTP test- problem
novomescan
FTP test- problem
Postby novomescan » Fri Mar 19, 2021 10:57 am
Hello.
I try to run a FTP test. ANT+ is recognized. But, when I press PLAY, I receive a warning.... Warning! To run this test you must have an ANT+ or Bluetooth Smart heart rate belt.
Please help with some advise.
M.
ymarti.ymarti
Re: FTP test- problem
Postby ymarti.ymarti » Fri Mar 19, 2021 12:41 pm
have you a belt cardio connected?
If yes...go!
GOD SAVE THE RIDER
novomescan
Postby novomescan » Fri Mar 19, 2021 1:02 pm
No, I just have ANT+
hernandez_christ
Postby hernandez_christ » Fri Mar 19, 2021 9:16 pm
Yes novomescan, your trainer is connected via ant+ and this is fine. But it is recommended that you wear a cardio belt during the ftp test as it is a violent exercise.
novomescan
Postby novomescan » Sat Mar 20, 2021 9:24 am
hernandez_christ wrote:Yes novomescan, your trainer is connected via ant+ and this is fine. But it is recommended that you wear a cardio belt during the ftp test as it is a violent exercise.
So without a belt it is not possible to perform an FTP test if I understand you correctly?
I have a POLAR M430 watch that has no belt but measures heart rate via a sensor on my hand. Is it possible how to connect M430 and perform FTP test?
Thanks.
hernandez_christ
Postby hernandez_christ » Sat Mar 20, 2021 9:57 am
Your watch handles BLE protocol so you should be able to connect it to the application and perform the ftp test.
The message in the application is not clear to me. It is a warning but it says you must have a heart sensor. To me "warning" and "must have" don't fit together so I don't know if the sensor is mandatory.
ymarti.ymarti
Postby ymarti.ymarti » Sun Mar 21, 2021 2:35 pm
My experience: with Garmin smartwatch the hearth broadcasting is not so good with the app.
My suggestion is to buy a belt (maybe cheaper like decathlon cardio belt).
Ciao
GOD SAVE THE RIDER
hypwuvky@wow4s.com
Contact:
Postby hypwuvky@wow4s.com » Wed Apr 21, 2021 5:10 am
ymarti.ymarti wrote:My experience: with Garmin smartwatch the hearth broadcasting is not so good with the app.
Ciao
Thank you.
totolekoala
Postby totolekoala » Sun Jul 11, 2021 12:14 pm
And of course, if you want to keep it free, use the FTP test from another platform (RGT cycling is free, and among the free workouts, they do provide both types of FTP tests and no need for a connected HR monitor there)
Cheers,
T.
Users browsing this forum: No registered users and 100 guests
