direto training test
Choose your ideal trainer
47stephen
Postby 47stephen » Wed Oct 18, 2017 5:53 pm
hello there, i am trying to do a training test on my direto using the my e training app , whilst doing it the direto is beeping most of the time , is this normal ?
kdviner
Re: direto training test
Postby kdviner » Wed Oct 18, 2017 11:12 pm
I have experienced that too. I am using ANT+.
Postby Elite Admin S » Thu Oct 19, 2017 9:55 am
The beeping sound you hear is the internal stepping motor that is adjusting the trainer resistance, it's normal.
During the normal use of the trainer, the sound should be merely noticeable.
47stephen
Postby 47stephen » Thu Oct 19, 2017 10:36 am
thankyou , also i have noticed that the resistance on the training test is very hard to pedal , it says i am pushing out 100w where in reality it is much higher , if i increase the speed and cadence it still says 100w , is this right and is my trainer faulty in any way
Postby Elite Admin S » Thu Oct 19, 2017 10:43 am
Have you done a calibration?
If not, do a 10 minutes warm up and then follow the calibration procedure.
47stephen
Postby 47stephen » Thu Oct 19, 2017 10:50 am
i have done a callibration test , it ran for about 20 seconds then said it was complete . I thought it would take longer to do than that so i tried again and the direto kept dropping the BLE signal when i started to pedal
Erkeki83
Postby Erkeki83 » Sun Nov 19, 2017 3:33 pm
El pitido es bastante más que perceptible, hay opción de quitarlo?? Gracias.
Erkeki83
Postby Erkeki83 » Fri Nov 24, 2017 4:08 pm
Erkeki83 wrote:El pitido es bastante más que perceptible, hay opción de quitarlo?? Gracias.
Postby Elite Admin S » Fri Dec 15, 2017 11:06 am
Hola Erkeki83
He visto que estas en contacto con la nuestra asistencia tecnica, por favor sigue con mi colegas.
Un saludo
