Is Direto XR compatible with TACX software?
Choose your ideal trainer
gguasti
Postby gguasti » Fri Jan 22, 2021 7:14 am
I am trying Direto XR with several third party apps (o.s. = windows 10)
Elite and Zwift can drive the tool power dinamically, but I got no luck with TACX software: no matter what the workout power is, the TACX software does not change the Direto XR resistance.
The connection seems solid: I am using Bluetooth for heart meter and Direto XR. In TACX app I see two available connections: One called Direto XR and one called CAD, used to probe cadence. Both are indeed related to Direto XR.
Is Direto XR compatible with TACS?
Has anyone of you managed a succesful connection between them?
Thankx
gguasti
Re: Is Direto XR compatible with TACX software?
Postby gguasti » Mon Jan 25, 2021 7:00 pm
it seems that nobody from Elite answers to most of the posts.
I would like be wrong....
richard927
Postby richard927 » Wed Feb 10, 2021 10:48 pm
i've got the same problem.
No resistant with the TACX software.
Is there anybody who can help ?
hernandez_christ
Postby hernandez_christ » Thu Feb 11, 2021 9:09 pm
I have no clue, have you checked also on tacx website if they can control other home trainer than their own?
Zwift, rouvy anc Co are third parties so they should be compatible with any home trainer but I wouldn't be surprised if an app from a home trainer manufacturer would not be able to control other brands.
