So embarrassed to admit this but I am unsure whether my turbo trainer is a smart turbo trainer and if I can use it with zwift. Can someone help please.
This is the one I have, it's quite a few years old now... https://www.sigmasports.com/item/Elite/ ... ainer/5G9E
How do I connect up to zwift? Or is it that I can't and I need to upgrade? Thanks
Does this trainer work with Zwift?
Re: Does this trainer work with Zwift?
Dear, I found your post about the elite qubo digital.
Have you found a solution for this? I own this too and would like to connect it with zwift.
From what I have seen you can't connect to zwift or any app. Looks like you control it through a device.
