ELITE VOLANO SMART B+
luiscarlospenasilva
Boas, comprei este rolo, nenhum treinamento de elite não pode passar os 30-35 k / h (com muita dificuldade) se usar no zwift e sem dificuldade nenhuma a 65 k / ele faz medias de 900wats. O que se passa? ou digite este código para 14 vezes (led), conforme as instruções. obrigado
Re: ELITE VOLANO SMART B+
After three years of use, I compared my readings on the Assioma pedals and got a 19% worse result. That is, the machine shows 19% more power than it has.
Maybe the fluid used for resistance has degraded during this time. Is there any way to replace it and with what?
Dopo tre anni di utilizzo, ho confrontato le mie letture sui pedali Assioma e ho ottenuto un risultato peggiore del 19%. Cioè, la macchina mostra il 19% di potenza in più di quella che ha.
Forse il fluido usato per la resistenza si è degradato durante questo tempo. È possibile sostituirlo e con cosa?
Hi Doooh
Are you sure to have properly set the misuro B+?
Check the number of flashes you've set, it must be 14 flashes
Ciao Doooh
Sicuro di aver impostato nel modo corretto il misuro B+?
Verifichi di aver impostato 14 lampeggi
Ciao Doooh
Yes, sure.
Colleagues have pointed out that the data are not plausible.
Misuro was checked many times - 14 flashes.
I think, the resistive fluid may have lost its properties with time and I could change it if know its viscosity index.
If the oil has leaked, of course power may sensibly decrease.
But it's not possible to add the oil on this particular trainer, I'm sorry, It requires special equipments to do it.
And a repair would be too expensive.
Perhaps those who pump hydraulic brakes can handle it?
I'm looking for any solution so I don't have to buy a new trainer - it's too expensive for me.
And the biggest problem is not understanding the characteristics of the oil. It's probably one of those used in industry and sold in stores.
Thanks for the insight.
It's a special oil, it would not be a problem to send it to you (we already do it for other trainer models).
But it's really not possible to do it on Volano, it's really a difficult operation
Thanks for answer.
Will think about powermeter pedals.
