I just got the Novo Smart trainer. It is replacing my Real Tour wired which is not longer supports but still will work with Zwift but I do not like Zwift.
Set up was easy, I watched the Shane Miller's video on YouTube where he set up a similar trainer by Elite and the process was simple.
The trainer connected with my PC Bluetooth with no problem.
It runs even smoother and quieter than the RealTour ran.
I would make sure if you have on a concrete floor you use some cardboard to hake sure it is steary when you ride.
The MyETraining software is great, ran with no problem, downloaded videos with no problem. Screen has a lot of data but is not cluttered. I thin Elite listened to the feedback users gave and made something that is very easy to use.
One suggestion I have for a PC user, if you don't have a wireless mouse use the USB extender cable so you can be on the trainer and start the ride etc. I just used the one I have from the Wired RealTour I bought.
I ran several short courses with no problem.
So far I am very impressed and would recommend the Novo.
I had given Elite a hard time over their previous Real Tour software but this is such a marked improvement.
Elite Novo Smart trainer
