How To Factory Reset Netgear Router | +1-844-245-8772
Choose your ideal trainer
ResetNetgearRouter
Contact:
Postby ResetNetgearRouter » Tue Jul 16, 2019 2:37 pm
Many a time while using Netgear Routers, the user with little knowledge of networking products are stuck i such a situation where they have no option left apart from resetting Netgear Router to bring it back to out of the box condition. Below mentioned are easy steps on how to factory reset Netgear Router. The same steps are to be followed to Reset Netgear Router Password.
There are two methods to perform Factory Reset Netgear Router. One is soft reset via web interface and other is hard reset via button.
Soft Reset Process:
Input url http://www.routerlogin.net or 192.168.1.1 in any web browser
Fill the username and password in the box.
Look for maintenance section and choose Backup Setting.
Click on Erase button and OK to confirm.
Hard Reset :
Locate the reset or restore factory setting button.
Use a tiny pointed object like any paper clip or safety pin and put it inside.
Press the button for 30 seconds and then release it.
Wait until the power LED starts blinking.
During Netgear Router Reset if you are stuck, then you can avail instant support from leading industry experts by dialling our toll-free number +1-844-245-8772. The experts are at your disposal round the clock.
