Discussion Do NOT delete native apps on iOS 13 Beta if you plan to re download them.
Choose your ideal trainer
Olympiapeter
Postby Olympiapeter » Fri Jul 05, 2019 4:33 pm
As many of you do and have done on previous software builds, you have deleted stock applications in iOS for whatever reason. In iOS 13 stock apps now run from a new SDK developed on Xcode 11 using swift. Once you delete your stock app in iOS 13 and try to redownload the app from the AppStore, you will be unable to. This is because the AppStore servers do NOT have support for apps to be recompiled in Xcode 11. This means you will be unable to reinstall native stock apps until potentially after the full release of this operating system, please spread the word.
xeniia
Re: Discussion Do NOT delete native apps on iOS 13 Beta if you plan to re download them.
Postby xeniia » Tue Jul 16, 2019 12:05 pm
very useful info, I will dowload it now! thank you for sharing with us
game hole io
