Roller damaged
Choose your ideal trainer
thecabbieman
Roller damaged
Postby thecabbieman » Mon May 20, 2019 1:08 pm
Hi. Does anyone know if I can replace the actual roller(spindle?) on a smart b+? Mine has developed a nick which is turning into a flap. I might have a go at gluing it down but I'm not sure how good this will be. Might be easier to just replace the roller.
dwtrux
Re: Roller damaged
Postby dwtrux » Mon May 20, 2019 10:41 pm
Doesn’t Elite website have rollers replacement in the product section?
thecabbieman
Re: Roller damaged
Postby thecabbieman » Tue May 21, 2019 11:28 am
I have had a look but can't find anything. I'll email them to see what can be done.
dwtrux
Re: Roller damaged
Postby dwtrux » Tue May 21, 2019 6:14 pm
Go to www.shopelite-it.com
Rollers are there.
Good luck
