Interactive or Smart?
Choose your ideal trainer
Elite Admin M
Postby Elite Admin M » Fri Dec 16, 2016 10:58 am
Interactive trainers are those trainers which has got an electronic control of the resistance. The versions currently in production use ANT+ Fe-C and Bluetooth Smart communication.
The resistance is controlled automatically by the my e-training app, the Real software or third parts which support the above protocols.
Interactive trainers are: Drivo, Rampa, Qubo Digital Smart B+ (and all the trainers of the Real serie)
Smart trainers are those which are able to send training data using ANT+ and Bluetooth Smart communication. Data can be visualized on my e-training app and on any other app or device that support those protocols of communication. This trainers don’t have an automatic control of the resistance.
Are smart trainers: Kura, Turbo Muin Smart B+, Qubo Power Mag Smart B+
Interattivo o Smart?
I trainer interattivi sono quei trainer che hanno al loro interno il controllo elettronico della resistenza. Le versioni attualmente in produzione utilizzano protocollo ANT+ Fe-C e Bluetooth Smart.
La resistenza viene regolata in modo automatico direttamente dalla app my e-training, dal software Real o da terze parti che supportino i protocolli sopraccitati.
Sono rulli interattivi: Drivo, Rampa, Qubo Digital Smart B+ (e tutti i precedenti prodotti della gamma Real)
I trainer Smart sono quei trainer in grado di inviare i dati di allenamento via ANT+ e Bluetooth Smart. Tali dati potranno essere visualizzati sulla app my e-training e su qualsiasi altra app o dispositivo che supporti tali protocolli. Non hanno controllo automatico della resistenza.
Sono rulli smart: Kura, Turbo Muin Smart B+, Qubo Power Mag Smart B+
MinevilleWest
Re: Interactive or Smart?
Postby MinevilleWest » Tue Feb 23, 2021 8:38 am
Interactive projectors have wide screens whereas smart boards with the projector set up will have smaller sized screen aspect rations. Interactive projectors can be used with or without a PC but smart boards compulsorily need a personal computer to function.
www.myaccountaccess.com
