Evertythings is fine and connected to Elite software.
The only problem i have is to do the calibration.
I can't do it with myEtraining.
I have a message who tell me to go faster; i did but no chnagement.
Best regards,
Calibration suito 2 with myEtraining impossible
thierry.carrasco
Re: Calibration suito 2 with myEtraining impossible
If you try with a different smartphone/tablet, do you have the same problem?
thierry.carrasco
Hello
I try with my Pc and also with my IPhone... same problem
I will try again
Best regards
I will try again
Best regards
If the problem persists even using different devices, contact the customer care at myetraining@elite-it.com
barry.gaunt
I had this happen with my Drivo II today.I solved it by setting the wheel size at the very end of the Drivo II configuration (after extra Power Meter/Cadence and the HR sensor questions) to 2096 and NOT to 611 (2096/3.43).
Could it be a similar problem for your Suito 2? I.e use 2096 not 84 = 2096/24.8?
