Hi guys has anyone seen this fault before.. the switch sometimes doesn’t connect and so gets pushed out the way and brass fitting falls off the lead screw , which I think controls the resistance.
Just guessing with all this I haven’t got clue!
I’ll post a video up
Drivo fault.. possibly faulty switch?
- C45A0D0E-1286-4558-BBDB-29B8E405CB2D.jpeg (76.48 KiB) Viewed 4367 times
Re: Drivo fault.. possibly faulty switch?
Can’t post vid
So, the problem is on the switch.
Please contact the customer care at myetraining@elite-it.com, the guys there will give you instructions to solve the problem
