I'd like to buy an Elite Suito and use it with my 3x7 speed bike. My cassette has the following numbers on it, (14-34T and MF-TZ31). It appears that the Suito will require a cassette other than the one that comes installed, some spacers, and adjustments to make it work. Can someone please help me with a list of additional parts that I will need?
Elite Suito accessories needed
Re: Elite Suito accessories needed
the free hub included with Suito is compatible only with 9-10-11 speed.
So, a 7 speed cassette is not officially supported.
You can ask your trusted mechanic to use some spacers and try to mount it anyway, but we cannot guarantee the correct functionality of the gear.
Any problem that may happen using a 7 speed cassette is not covered by warranty as we cannot guarantee a correct assembling
