Which circumference value do I have to use?
Choose your ideal trainer
zetxek
Re: Which circumference value do I have to use?
Postby zetxek » Sun Dec 15, 2019 9:27 am
What's the value to divide by with Suito?
blair
Postby blair » Sun Dec 15, 2019 9:23 pm
zetxek wrote:What's the value to divide by with Suito?
Divide actual circumference by 24.8
It's on page 39 of the manual.
frtosi63@gmail.com
Postby frtosi63@gmail.com » Thu May 07, 2020 10:28 am
Elite Admin S wrote:I'll do it soon, sorry.
About Direto:
- if you use my e-training app or software, you have to set the real circumference value of your wheel (for example, 2100mm)
- if you use a non-elite app or device (like Garmin), you have to divide the circumference value by 12.1 (for example, 2100/12.1= 173mm)
Buongiorno,
ho un edge 820 e un Direto X, dove ho inserito il valore della circonferenza ruota/12.1, ma la velocità non risulta corretto (al max. 4km/h).
Mi chiedo inoltre quale sia il valore da impostare in Rapp. Trasmissione
Grazie
fab4mas
Postby fab4mas » Tue Sep 08, 2020 8:06 pm
About Direto:
I see that my edge detect a wrong speed compared to zwift (about 4 or 5kmh less for the direto).
I paired the direto as a speed sensor in edge menu with a wheel size of 174mm but it seem that edge calculate my speed not with direto speed sensor (it si the same with 2096 or 174mm).
do i have to edit the wheel size in mytraining app too?
Users browsing this forum: Google [Bot] and 3 guests
