Novo force 8 + Misuro B+ et zwift
y.azaud
Postby y.azaud » Sun Jan 12, 2020 11:24 am
Bonjour,
Quel est la marche à suivre pour pouvoir se connecter sur zwift.
Actuellement, lorsque je me connecte, le misuro est reconnu mais quand je pédale, mon avatar reste sur le bord de la route.
merci pour votre aide
What is the procedure to be able to connect to zwift.
Currently, when I connect, the misuro is recognized but when the novo force 8 specifies and that I pedal, my avatar remains on the side of the road.
Thanks for your help
mchereja
Re: Novo force 8 + Misuro B+ et zwift
Postby mchereja » Mon Feb 24, 2020 11:11 am
I have the same problem, is there a solution? Thank you.
thalescyrino
Postby thalescyrino » Sat Apr 18, 2020 7:21 pm
I think you need to configure misuro, I tryied to config to 9 blinks, an d I using in the level 3.
https://www.youtube.com/watch?v=7KuNrMiD4vE
camille.rolin1
Postby camille.rolin1 » Fri Apr 24, 2020 9:26 am
Hi, have exactly the same problem. Did anybody find a solution ?
Thanks for your answer.
Postby Elite Admin S » Fri Apr 24, 2020 5:14 pm
In this particular case, as the misuro cannot "know" the level set on the selector, the misuro only sends speed and cadence.
This means that you have to configure the trainer as a speed source and cadence source.
Also, you'd have to set a proper circumference value (that is the roller circumference, so 94mm).
Finally, set the level at 3 as they require.
camille.rolin1
Postby camille.rolin1 » Fri May 01, 2020 4:11 pm
Hi, thanks for the answer.
Could you please explain how to configure the trainer as a speed source and cadence source ? And how do we set a propoer circumference value ? I am not sure to understand what it means ...
Is it on Zwift app ? On Elite app? Do we have to change the « blinking »?
Because for me, the Zwift app doesn’t recognize my speed but it sees the Misuro...
Thank you.
Postby Elite Admin S » Mon May 04, 2020 5:57 pm
Check this document:
https://elitesrl.zendesk.com/hc/en-us/a ... n-on-Zwift
If still you have doubts, I suggest you to contact directly Zwift support
kevaket
Postby kevaket » Thu Oct 29, 2020 9:56 pm
Bonjour Camille, vous avez réussi à paramétrer le misuro B+ ? J'ai le même problème que vous
raquel.delval
Postby raquel.delval » Mon Nov 09, 2020 6:59 pm
Hi! We are trying to configurate misuro b+ for our novo force 8. We are using 1 bling and setting circumference equal to 94mm but both in my training app or using a Garming 520 we get an average speed of 4kmh.
Any of you have the same problem? Do you know how to solve it?
