10% grade and 800watts vs 5% grade and 645watts.
Only you can decide if you need to spend the money. If you haven't ridden on rollers before, I strongly suggest you try to borrow or buy a crappy dumb set off craigslist and see if you actually like it. I went with a wheel-off smart trainer and I am happy to be able to lean over and grab the remote to change the channel on the TV...
Arion Digital Smart B+ Rollers vs InsideRide E-Motion
bobbybrian
Re: Arion Digital Smart B+ Rollers vs InsideRide E-Motion
Thank you so much for the link..It is really helpful..Let this good work keep coming My Pasco Connect
