Hi Guys,
I am hoping someone could please help me. I have just purchased the Elite Drivo. I have a 10 speed cassette which I would like to install on my new Drivo. Do I use the 2 spacers that come with the trainer as well as the metal spacer that is provided with the cassette? Or do I just use the 2 spacers provided with the trainer from Elite.
10 Speed cassette help for Drivo
Re: 10 Speed cassette help for Drivo
One spacer of the ones we put in the box should be enough with a 10 speed cassette.
But depends on the specific situation. Try with one and check if all is well fixed, otherwise add the second one.
I had to use both spacers that came with the drivo + 2 spacers from the cassette itself.
I installed a 10speed sunrace (Mtb) if that works for something
I used 2 Spacer with my Shimano XT cassette CS-M771-10
Thanks guys. Mine is a 10 speed Ultegra cassette. Is this different?
