This is for my Elite Rampa.
The version I found seems pretty buggy for calibrating the p123 numbers (only works some of the time). Is there an updated version?
Also it seems like my Rampa reverts back to factory p123 numbers if I unplug it. Is it ok to leave it plugged in all the time when not using it?
Is there an updated real trainer Calibration tool
Re: Is there an updated real trainer Calibration tool
The values you see when you accede again to the app are the default ones.
The one you've put are saved in the trainer electronic board.
When the calibration doesn't work, it means that there has been some interference. Verify to not have other wireless devices in the area while you do the calibration and if the problem persists contact our customer care at real@elite-it.com
