Rizer calibration variation problem
pierre.lepeer
Postby pierre.lepeer » Sat Feb 15, 2025 1:52 pm
Hello everyone,
I don't know if this is the right place to ask, but I have a Rizer with which I encounter a curious phenomenon, at least on Zwift:
I calibrate it to have the handlebars straight before riding, but as I ride, little by little, I deviate more and more to the left, which I gradually have to compensate for by initially turning slightly to the right to ride straight, but after two hours, I'm almost with the handlebars at maximum right. If I calibrate it again while riding, everything returns to normal at first, but the phenomenon returns.
What could be the reason (and the solution)
sternwicked
Re: Rizer calibration variation problem
Postby sternwicked » Wed Apr 23, 2025 6:26 am
It sounds like there might be an issue with the calibration or alignment of your Rizer, possibly due to uneven resistance or wear in the components. I recommend checking the setup for any loose parts and considering a factory reset or reachingschoolboy runaway out to the manufacturer's support for assistance.
misa99
Postby misa99 » Wed Jul 16, 2025 12:15 pm
Have you noticed this happening when using apps other than Zwift? And are you using a self-balancing controller or any other accessories?
Granny Game
