To use without power
ymarti.ymarti
Postby ymarti.ymarti » Wed Jan 24, 2024 2:34 pm
Dear all,
In your opinion is possible to use the smart trainer (I have Suito) without power cable and so electric current?.
Any trobule?
I would like to use the trainer for 5-6 minutes for war-up e.g. before functional WOD (home gym).
Thank you for feedback
GOD SAVE THE RIDER
Re: To use without power
Postby Elite Admin S » Thu Jan 25, 2024 11:33 am
You can use it, there are no problems. Simply you won't have the control of the resistance or any data
ymarti.ymarti
Postby ymarti.ymarti » Thu Jan 25, 2024 12:58 pm
GRAZIE! Thank you!
GOD SAVE THE RIDER
misa99
Postby misa99 » Sat Dec 14, 2024 8:48 am
Using a smart exercise machine like Suito without a power cord and current is completely possible, as long as you use it for a short time like 5- Block Blast 6 minutes to warm up. However, make sure that you do not encounter any battery or performance issues when using it for a long time. If you feel that the machine is running unstable, it is best to check again or fully charge the battery before using it.
Users browsing this forum: No registered users and 38 guests
