Configuring power reading
Nigan
Postby Nigan » Tue Nov 23, 2021 2:51 pm
I cannot configure the power reading for my Direto. I am using bluetooth, the trainer and cadence sensor configuration is fine but when i try to configure the power sensor in settings it asks me to start pedaling which I do but even after 5 minutes nothing happens. Any suggestions? Do I need a separate power sensor on the bike
Re: Configuring power reading
Postby Elite Admin S » Fri Nov 26, 2021 11:10 am
You don't have to configure the trainer as a power sensor.
That option is used only for external power sensors (for example Assioma pedals).
The same for cadence.
Repeat the configuration and when you're asked if you have external power or cadence sensor, leave the option on NO.
This should solve the problem
